Josh's 225 TT Quattro - Now E92 M3!
Most of this is copy/pasted so there may be some format issues!!
Jan 12th 2014
Afternoon all!
I thought seeing as I'm currently TT-less and have been for 3 weeks I'd write about it instead :) so I took a trip up the Leicester from Cardiff to look at a nice 225 which after a lengthy trouble free test drive I decided to buy!
On my 170 mile trip home I noticed the speedo wouldn't smoothly step down when decelerating it would stutter down in 5mph-ish increments :( eurgh! But other than that a slight vibration was present at 50-70mph which I put down to the wheels being out of balance.
So here she is!
C438DF93-CBAC-4581-8251-470ADE6A0870_zps
02EE87A8-2A99-4299-9E81-20E38072A951_zps
So the story goes on! Driving to work the next day full of enthusiasm with my new purchase, I notice the speedo needle is totally dead :( I don't know if this is a dash pod issue or G22 gearbox speed sensor!?
Half way to work I pull off hard from a roundabout and BANG BANG BANG! Massive knocking from the centre of the car - FFS!
Limped to a layby just ahead
974847CE-4E92-4CE0-B7D0-F3E9E250C4E4_zps
As I'd suspected a CV joint exploding, I rang my local vw specialist and arranged recovery. Just as I'd come to a stop in the layby the yellow oil light came on, then the clocks died completely, car would run for 3 seconds then die.
So fast forward through Christmas and the garage have finally taken her to bits, found out that the props front coupling had totally destroyed itself - it was missing the metal collar that connects the prop to the transfer box so the full power was being transferred through the torque damping rubber coupler!
As the prop was banging about it tore through the sump oil sensor wiring, which I think I was what caused the clocks to die :(
While it was there I asked for a full service and inspection, haldex oil/filter and timing belt change.
The auto elec brought the clocks back Friday having re soldered a few things but the fuel gauge wasn't playing ball this time so they came back out - I'm not sure about the speedo!
While I've been without it I've been merrily spending away online shopping :p
Forge Knob
C60D7769-25C8-4F12-B68B-9F7CCC8ADD4A_zps
Jetex cone
6BFD5D61-627A-4B93-A993-FD0D1C2381FA_zps
Forge vac pipe
2F4D86A8-DED3-4273-831C-44AE9E631AD2_zps
Les's handle covers
801CAF6F-AD2B-4DE0-B13E-D4BFECD15DC6_zps
LED/Cree sidelight/number plate light.
AE26E15C-0944-46FE-B2EE-44E6E522B5C4_zps
Cookbots!
4F8DC184-993B-47F1-A986-AAC6F527474A_zps
Quick shift
241ABB5A-7392-491D-8F7E-0CE1A0E8711E_zps
4 x Vredstein Ultrac Sessanta
F8E4BF3A-AAE7-4192-8516-86223FC4D911_zps
20mm spacers for rear (15mm to follow up front) and a scorpion catback with Daytona tips.
Well, that's quite a lot for now! Will update when I actually have the car.
TL:DR version - I bought a car, I broke it, I bought lots of things to make me happy.
  • Replies 94
  • Views 8.2k
  • 1 week and 3 days until castle Combe, 6 hours of work and were here.... Also degreased and cleaned and painted my subframe yesterday. Engine will be out tomorrow!
  • Confirmed collection tomorrow :D :D
  • Finished fitting turbo and manifold yesterday, got it all torqued up etc That manifold is evil, majorly awkward nuts I'd HATE to do it with the engine in situ! Went out and grabbed a clutch, fly
It's back!!!
£1,354 bill :o
After the garage knocked a full days labor off the bill too!!
Propshaft coupling
Sleeve inside prop coupling
Transfer box output shaft seal
Oil sensor wiring repaired
Timing belt and waterpump
Haldex oil and filter
Clock overhaul
Headlight switch
And lots more!
This arrived..! Fitting next week :)
4492AE0F-496E-4CBE-B2C2-66AF503FD187_zps
Long over due an update!
Fitted an SFS TIP and eBay heatshield
CDFB8B01-E40E-41F6-854B-920AB7C9AEEA_zps
578D1E33-E46F-4088-BF2F-BE210DD04C01_zps
Unfortunately found LOADS of play in my turbo...here we go again!
Never one to be beaten I decided to order up a hybrid from beach buggy turbos..
09E289DD-CD3C-4B99-90DD-2F74574B699F_zps
F589F452-1CC9-462E-911C-555374A5CB8F_zps
24CD137B-4C8D-47A8-B840-E0BEAE431DB5_zps
Seeing as I was doing this, I may as well have got a decat to match my turbo and scorpion catback!
6A70F2F1-26CD-4D53-98B6-D367CC610EE0_zps
Here's a rear shot of my catback - notice rear light patch
002D534E-F9AA-433C-B0E8-4C559194DDD2_zps
Had turbo fitted along with downpipe, a new sump, thermostat, red powerflex dogbone bush, black powerflex steering Rach bush and an oil/filter change.
I've replaced the entire vac/breather assembly under the inlet manifold this weekend with brand new OEM/Upgrade Pipework, pcv valve etc. Also cleaned throttle body as it was STINKING!
Have fitted brand new oem DV, MAF and N75. I have coil pack adapters and red TFSI coil packs coming.
This Sunday I fitted my HG motorsport FMIC, Forge upper boost pipes and polished charge pipe!
D2654145-ED16-4E53-972F-E76928EEBE7E_zps
So much has been done I've probably missed loads
Will try and keep this updated.
Before I'd touched the car VCDS logs showed 223bhp.
Did a log today with the car as she stands not mapped....248bhp!
Bill Badger5 mapping this April 6th and also fitting 550cc injectors, can't wait, would like to break 300bhp!
That brings things up to date!
A couple more pics,
6D7130DF-627E-44E7-BF32-1499C0E3ABE4_zps
21A51635-F0D6-4CF2-9FFE-30A2E470879E_zps
Been shopping!
0F6A2876-0F5C-4AAD-9F29-BCCDA09B4FBA_zps
Wow, some serious investment there mate! Cracking car.
sent from my Galaxy Note 3
Thanks mate! This one seems like a keeper for a little while yet :)
Great work Josh, looks brilliant :)
nice mods being done to this,money being spent too!
Yes mate, getting a lil expensive (more than the car cost already!)
Ordered AP coilovers today, need a front and rear ARB upgrade now!
Love this Josh!
Looks epic Josh. You tracking it at Coombe?
Looking good, always liked the MK1 TT.
Cheers guys, not planning a track session for April unless anyone sells me a session on the day.
There's still quite a lot to do on it at the moment, I'm hoping to have the coilovers fitted, mapping done and brakes fitted if they arrive in time, we shal see!
Cars boring and slow as I'm driving around with the N75 unplugged until mapping, decided I was far better off safe than sorry!
I managed to press my cookbot bushes into my spare wishbone with a vice yesterday so I was pleased with that for sure!
42960DF7-D6E3-4810-8E7F-D25BC1386AA2_zps
Plan to fit superpro caster correction bushes to the rear ones too to complete the set up.
Got a nice plan for when the coilies arrive:
•New Delphi bottom ball joints.
•Spare pair wishbones painted satin black with my bushes pressed in in advance to save time.
•New drop links.
•New top mounts (LCR or powerflex!?!)
•Powerflex rear trailing arm bush and a lick of satin black on the arm.
•Adjustable rear tie bar in lower position, top arm given a paint and a new Powerflex bush.
•D2 6 pot 330mm front BBK.
Only just spotted this , nice work there mate. Seems like you've spent a few bob haha. I have heard very good things about Badger5 so you are in safe hands there.
Those turbos are a pig to fit on these BAM engines!! Do like the mk1 though! Has the wiring repair helped the dash pod issue have these coming in a lot to have dash replaced due to none starts etc!
I think my manifolds split...or it may be a gasket.
But I went ahead and bought a Relentless V3 manifold anyway :D
24360E57-A146-44AF-BE9B-BAC0918D1E75_zps
It's ideally a head off job...so I may as well do rods!!?
Also bought an upgrade 15psi turbo actuator.
Edited by JoshH
tasty :evil:
Manifold porn. I am incredibly jealous of this project lol
Nice work. The Mk1 shape is ageing well, definitely.
Don't forget your avatar and car profile info update though :)
1D9017D0-F274-4FAF-B566-D312C4106BCB_zps
C8298063-5FBC-42FB-9AC7-DBC49ED19B9C_zps
CD2F8D27-A171-4009-9EDD-81F03D44849C_zps
FBF4A938-6F03-4D05-991A-4C1517C69F83_zps
B5FB2633-5956-494E-B6FB-44863D61ECA3_zps
31B6CAF7-325F-419B-8434-B2CD61F6F15B_zps
B8724046-DE8E-4AEB-90BD-C40EFE84B2D4_zps
Today was a good day, until I realised there were no pads, brackets or fitting kit included with the brakes, grrrr!!!
Those calipers are tiny ;)
I'm so jealous :( some big brakes for the front of mine next I think :)
Manifold looks awesome too!
Fair play Josh you are turning the TT into a weapon! Some good choices on the mods so far. :-)
Thanks Lee, are you at Castle Combe in April?
D877DF4B-F45F-49EF-9E59-43855CE23891_zps
Trial fit today!
Pads and fitting kit not here til midweek next week!
I'm thinking this thread should begin with a XXX warning for pornographic mechanical imagery!  Keep it up and we all may go blind?   :yes:
