head unit
fitted jvc dab head unit all works fine memory the lot but how do i get it to switch off when i take the key out any help would be appreciated
Aftermarket headunits quite often have the permanent and switched power lines reversed.
Not sure what age you octavia is but when I fitted a hands free kit into mine there is no ignition switched live present at the quadlock connector.
The stereo is switched on & off using a data signal via the multiplex (Canbus) system. So you only have 2 options:
1) Get your ignition switched live from the fusebox to the right of the steering wheel
2) Buy a Canbus decoder which will read the data signal and give you a traditional switched 12v
This is assuming you have a quadlock connector, if you have an ISO then see John999boy's post as I have seen this a lot.
Edited by xpower
I fitted a piggy back mini fuse into the towbar electric fuse on mine, works a treat and is switched live, takes 5-10mins to put in!
