How to remove front seat headrests
Hi frends;
Last week i bought seat cover. I like to wear them but i fail to remove seat headrests.
In the manual writed as follows:
"front seat headrest can not be removed"
Does anyone have an idea about how to be removed headrest.
Thank in advance
by Danish manual may be removed.
Setting and removing and installing the headrest
FIG. 44 Headrest: Setting / Removing
Read and follow only the introductory information and safety instructions
on page 61
Adjusting the headrest height
> Hold the headrest on the sides with both hands and push it up as
much as you like 'Fig. 44 - ?.
> If you want to adjust the headrest lower, use one hand press
the lock button »Fig. 44 - ? and hold and with the other hand
press the headrest down.
Removing and installing the headrest
> Pull the head restraint all the way out of the seat back (fold the backrest forward for
the rear head restraints).
> Press the release button in the direction of the arrow »Fig. 44 - ? and pull the headrest out.
> To reinstall, push the head restraint down as far in the backrest that you
can hear the lock button engages. ?
ä
Seats
on page 61
ä
Seats
Thank you for answer.
I try to found danish manual but i could not find.
If you have link for danish manual, please share link for me.
Thank you.
I found english manual. English manual is the same with Turkish manual.
Page 73-74
http://ws.skoda-auto.com/OwnersManualService/Data/en/Octavia_5E/11-2013/Manual/Octavia/A7_Octavia_OwnersManual.pdf
Patch: I like to see fig.44 and apply.
Edited by Levcho
jeg kan se at i den tyrkiske manual starter det på side 71 hvodan man afmontere nakkestøtten
I was sorry that the first was in Danish. I can see that in the Turkish manual starting at page 71 Till when you remove the headrest
@sokobowits, so thank you for commentar.
Tomorrow i will see  caar for resolve for this problem.
In the English version it says...
Removing/installing
Only the real head restraints may be removed.
  • ›Pull the head restraint out of the seat backrest as far as the stop.
  • ›Press the locking button in the direction of arrow 1 » Fig. 49 simultaneously
  • press the locking button into the opening 2 using a flat screwdriver with a
  • width of maximum 5 mm and pull out the head rest.
  • › To re-insert the head restraint, push it far enough down into the seat backrest
  • until the locking button clicks into place.
I suspect the word "real" is a typo and should read "rear"????
Edited by Smeghead
Hi frends;
Warning!! If you fit seat covers this will interfere with the side airbags which are integral in the seat backs!
Hi guys;
Thanks for all commentary. I resolve this situation.
Under plastik cover, have a button for lock/unlock mechanism a movement on the headrests.
Look foto;
  • 2 years later...
Hi guys;
Look foto;
Why i can not open this pic? is already deleted?
Well it was posted 2 and a half years ago
