1.9TDi warm starting problem
1.9tdi Elegance Estate 2001 has started to be difficult starting when warm. The engine turns over easily enough. It feels as if there is no fuel being fed to the engine! I had thought it was the load sensor wire as I found this to be broken - since repaired but not effect on starting. If anyone has had this problem, I would be grateful for the solution.
many thanks.
Engine coolant temperature sensor most probably knackered. Easy to change , around 25 notes for OE part.
Sounds like the coolant temp sensor! solved all sort's of niggly issues with my 1.9tdi pd100
I paid about a £5 for a non OE part (trade price) but they should be available for under a tenner!
Such a strange part :D
Coolant sensor or ASV stuck shut or timing
Thanks for the help everyone.
I have changed the coolant temp sensor and still getting same problem. Engine wont start when beginning to warm up. Starts fine when cold!
What is the ASV which Green Briskodian suggests may be stuck shut?
Many thanks
did you get this sorted ? maybe daft question but when were the glow plugs last changed ?
Would it need the Glow plugs though to start the car when the engine is hot? Surly he would have bigger problems when starting from cold.
if the ASV gets stuck the engine spins over with no compression, so goes really fast on the starter. Sounds like you need someone with vcds to plug in and make sure first the temps read correctly and then see what the cranking rpm is, as a worn starter will not quite spin it fast enough to catch when warm (it is possible to work around this with MPPS and tweaking the map tho).
What is the battery like? IIRC the ecu chucks fuel straight away from cold but when warm the engine has to be turning over at 250rpm or more before fuel injection starts.
+1 on the above. Also it could be the starter motor on the way out, so again the engine isn't cranking fast enough to allow the ECU provide fuel
when the engine is warm try unplugging the CTS and see if it starts OK.
Hi guys, Thanks for all the good advice. Problem still not solved!
Starter motor ok I have even tried starting from warm with a mains cranker/charger. Engine turns quickly but not starting. I have changed the temp sensor. The EGR solenoid seems to be working in that it opens fully after 3 seconds after switching off. It does not get stuck as I have checked with the air pipe off. Could the MAF sensor cause the engine not to start when warm?
many thanks
Are there any error codes stored on the ecu?
SN
disconnect the coolant temp sensor next time it doesn't start and see if that helps.
I've now done a scan with VCDS-Lite.  Results are below:
VCDS-Lite Version: Release 1.2
Monday, 28 April 2014, 17:17:23:18549
Chassis Type: 6Y - Skoda Fabia I
Scan: 01,02,03,08,09,15,17,19,25,37,44,46,55,56,76
Address 01: Engine       Labels: 038-906-019-AJM.LBL
   Controller: 038 906 019 AF
   Component: 1,9l R4 EDC 0000SG  1110
   Coding: 00002
   Shop #: WSC 13765
   VCID: 5BC95C1ADA3D
   TMBGS46Y823332671     SKZ7Z0A1020948
4 Faults Found:
19463 -  Camshaft Position Sensor (G40): No Signal
            P3007 - 35-10 -   - - Intermittent
17552 -  Mass Air Flow Sensor (G70): Open or Short to Ground
            P1144 - 35-00 -   -
17664 -  Engine Coolant Temp Sensor (G62): Open or Short to Plus
            P1256 - 35-00 -   -
17571 -  Fuel Temp Sensor (G81): Open or Short to Plus
            P1163 - 35-00 -   -
Readiness: N/A
Address 03: ABS Brakes       Labels: 6Q0-907-37x-ABS.LBL
   Controller: 6Q0 907 379 D
   Component: ABS/ASR 5.7 FRONT   V00
   Coding: 00188
   Shop #: WSC 13765
   VCID: 3E0FF58E296F
No fault code found.
Address 08: Auto HVAC       Labels: 6Q0-820-045.LBL
   Controller: 6Y0 820 045
   Component: Klimaanlage        X0760
   VCID: F29791BEADB7
Address 09: Cent. Elect.       Labels: 6Qx-937-049-B.LBL
   Controller: 6Q1 937 049 B
   Component: BORDNETZ-SG.        1S31
   Coding: 25786
   Shop #: WSC 13765
   VCID: 3A07F99E3547
4 Faults Found:
00511 -  Selector Lever (E313)
            49-00 -  No Communications
00778 -  Steering Angle Sensor (G85)
01324 -  Control Module for All Wheel Drive (J492)
01309 -  Power Steering Control Module (J500)
Address 15: Airbags       Labels: 6Q0-909-605-VW5.LBL
   Controller: 1C0 909 601 C
   Component: 02 AIRBAG VW51        01
   Coding: 12338
   Shop #: WSC 13765
   VCID: 20332BF6B3DB
1 Fault Found:
00532 -  Supply Voltage B+
            07-10 -  Signal too Low - Intermittent
Address 17: Instruments       Labels: 6Yx-9xx-xxx-17.LBL
   Controller: 6Y2 919 870 D
   Component: KOMBIINSTRUMENT VDO V09
   Coding: 22441
   Shop #: WSC 65769
   VCID: 5BC95C1ADA3D
Address 19: CAN Gateway       Labels: 6N0-909-901-19.LBL
   Controller: 6N0 909 901
   Component: Gateway K<->CAN    1S31
   Coding: 00014
   Shop #: WSC 13765
   VCID: F0939BB6A3BB
4 Faults Found:
Address 25: Immobilizer       Labels: None
   Controller: Bit teA dre ss
   Component: e 17 eingeben
   VCID: 5AC7591ED507
No Faults Found
  or DTCs not supported by controller
  or a communication error ocurred
Address 46: Central Conv.       Labels: 6Q0-959-433.LBL
   Controller: 6Q0 959 433 C
   Component: 0J Komfortgerát     0003
   Coding: 00259
   Shop #: WSC 13765
   VCID: 3B09FC9A3A7D
8 Faults Found:
01134 -  Alarm Horn (H12)
            37-00 -  Faulty
01330 -  Central Control Module for Central Convenience (J393)
            52-10 -  Supply Voltage Too High - Intermittent
            53-10 -  Supply Voltage Too Low - Intermittent
01331 -  Door Control Module; Driver Side (J386)
01332 -  Door Control Module; Passenger Side (J387)
01333 -  Door Control Module; Rear Left (J388)
00934 -  Electric Window Motor; Rear Left (V26)
            08-10 -  Control Limit Surpassed - Intermittent
01334 -  Door Control Module; Rear Right (J398)
End   --------------------------------------------------------------------------------------------------
Where the CTS and MAF disconnected when you did that scan?
A couple of years back I had an intermittent problem with starting when warm. Like your symptoms the engine would just turn for a while before firing. The problem turned out to be a faulty cam sensor. They're easy and cheap enough to replace. Plus it's come up on your VCDS log.
Guys,
Again many thanks for replying to my last posting, it's much appreciated.
Last night I re-ran VCDS having checked the relays under the dash, all fuses and re plugged all the connectors in the engine compartment and inside.
I was suprised to find that the engine faults had cleared! Only the EPS remains a problem. Life is not that simple is it! Ran the engine up to running temperature, switched off and found that it did not want to start until the 3rd attempt.
The CTS & MAF sensors were connected as were all the sensors when I re-ran the diagnostics.
I have read that the steering angle sensor can play havoc with the electrics if it is faulty. I think I will replace this sensor as it is still showing up as a fault.
I was wondering if VW/Skoda got Microsoft to write the coding for the ECU & installed some version of windows, If so it would answer why we have these problems!
VCDS print out:
Tuesday, 29 April 2014, 20:05:51:18549
   Coding: 00002
   Shop #: WSC 13765
   VCID: 5BC95C1ADA3D
Readiness: N/A
   Coding: 00188
   Shop #: WSC 13765
   VCID: 3E0FF58E296F
   VCID: F29791BEADB7
   Coding: 25786
   Shop #: WSC 13765
   VCID: 3A07F99E3547
4 Faults Found:
   Coding: 12338
   Shop #: WSC 13765
   VCID: 20332BF6B3DB
   Coding: 22441
   Shop #: WSC 65769
   VCID: 5BC95C1ADA3D
   Coding: 00014
   Shop #: WSC 13765
   VCID: F0939BB6A3BB
4 Faults Found:
   VCID: 5AC7591ED507
No Faults Found
   Coding: 00259
   Shop #: WSC 13765
   VCID: 3B09FC9A3A7D
8 Faults Found:
            37-10 -  Faulty - Intermittent
Again thanks for your continued advice.
James
  • 4 weeks later...
Problem finally solved! I have replaced the following:
  1. Relays
  2. Starter motor
  3. Camshaft sensor
  4. Speed sensor
  5. Coolant Temp sensor
  6. Battery
  7. Power steering pump
  8. Steering Angle sensor
I discovered the replacement camshaft sensor was faulty. Car now running like it should.
Thanks everyone for all their advice and help, much appreciated.
Bloody hell, that's quite a journey to discover that a new, replacement part is on ther fritz. :o
Is it certain that it is/was the sensor? Wiring in the car is 12+ years old now. And the 1.9TDI isn't the smoothest of 4 potters.
Glad to read it's now behaving more reasonably. :)
