Pcd offset on wheels
What is the pcd on the octavia vrs, I can get some wheels I have been told the pcd 5.12 will they fit? Thanks jimmer
PCD is 5x100
5x100
Et35is a good starting point
And 8j width
What size u after bud
The off set pcd on the wheels I've been offered are 5x112, so I'm guessing they won't fit? There 18inch wheels with 2254018s on, any recommendations for wheels
Not without buying some adapters.
Ok thanks:-) where would I get adaptors and are they expensive ?
If running adaptors you'd need a et50 to et45 lowest tbh
As bolt on adaptors start at 20mm bud
I used h&r
Can be sourced from damian@ dpm performance
£125 per pair
H&r are the best , light and solid and threaded inserts rather than the thread in the alloy like fk
Whats the offset of the 5x112s ur after bud
Like so
Thanks for all the advice but I'm probably going to get the standard wheels powered coat black and refurbed, spacers and that seams like a lot of money just to put 18s on :-)
If u want to use 5x112 then it ads up quick
Some bargains on ebay,you might get lucky....I did :rock:
Stick with 5x100mm though.
