photoshop request
hello can anyone photoshop me some wheels on a picture of my superb please
PK10XNS(15)
with these wheels 1st
and then these
and these aswell
cheers vrsadz any help would be appreciated
Would be very much easier if you have a side on photo of your car (rather than 3/4 one)...
Ok if i put a side photo on can it be done
Sent from my GT-S5830 using Tapatalk 2
here is a side picture of the car is this any better
cheers vrsadz
Pretty quick but gives you an idea
cheers for that pasty boy
no bother
and Scirocco turbine wheels every single time without a moments doubt
cheers, was thinking the bentleys but there 19`s and tyres are expensive etc, thought the vw vancouver ones look ok but im more for the sirocco ones tbh
could you do these aswell please so that i can compare between matt black or standard
and try these aswell please
The Bentleys look well, but the amgs are the best of the bunch ;)
tbh dont think the merc ones will fit because the centre bore is bigger at 66.6mm rather than 57.1mm
Spigot rings will sort that ;)
cool rather just have them bolted to the hub. do these fit inside the rim before you bolt it to the hub
Yes mate, they just reduce the cb so they locate properly on your hub. I run merc spec rims and have them fitted
cheers ill keep them in mind if i go for the merc wheels
can somebody photoshop these on for me please
like this only better
cheers for that pasty boy.
can somebody lower the last one with the merc alloys, just a little drop like its on lowering  springs
cheers vrsadz
can somebody photoshop these wheels on please
as per PM
Black BBS CH's as requested
Not sure on the black CH's
Suit just about every vag car ive ever seen, but that doesn't do anything for me im afraid
Back to the drawing board fella (or go with my suggestion ;))
