Snapped hub spreader!
Snapped the bloody hub spreader tool trying to open the hub.  :wall: Money well spent there, I was probably doing it wrong....
Any tips on getting the ******s off/open? Sprayed it with half a can of WD40 and gave up tonight.
They are an a***, have done it with a large GS (big flat blade screwdriver). New tool would be easiest even though annoying.
+1
You should be able to lever it open with a large flat screwdriver or smallish crowbar or similar . It is only to open the hub. Tapping hub with hammer works too if you have sprayed with loads of WD40. :thumbup:
I knock a big wide chisel in from the top then knock the hub down the shock with a hammer.
screwdriver + hammering = its off!
now not sure how the new topmount fits, doesnt appear to fit on like the old ones...... :giggle:
It don't fit like old one as old one is held down with the original nut. Those poly bush top mount just sit on top of strut and placed up to car turret. Put loads of grease on the mounts as they will squeak otherwise. Also if you are re using your old top mount metal cups they will be sitting higher with the poly bushes. You can read my thread on fixing that.
Sent from my Samsung S3
I used a socket mounted allen key to part mine and a hammer to encourage it down the shock.
A series of Allen keys work better. Insert a key and turn it so the next size up will go in. Then turn the new key until the next size will go in...
Top cups seem to sit fairly well, not as high as I have seen.
Pics dude....
Tell a lie, its highish.  :giggle:  I can live with it so long as its not a problem?
That is not as extreme as i have seen it
The only issue is when you drive over uneven road as with that gap the strut can drop and clunk
Least you can fix it without taking strut off
that is why i modded mine
Yeah, seen your thread. Might attempt it if I have any issues. :)
