WOBBLY BOB
Any ideas why I am getting a slight wobble when coming to a stop please?
Cheers..
through pedal or steering wheel
if its a wobble on steering, id be putting it down to either -
a) loose, misaligned brake pad / warped disc.
B) a bad bushing / bolt / drop link in the front end thats only getting loaded under braking.
Get it jacked and give everything a good shake about and check..
No wobble in the steering, solid as a rock? The discs and pads and anti roll bar bushes, wishbones were replaced with new ones 6 months ago? Not ruling out bad bushes, drop links and discs, as all the above mentioned parts only cost £120.00 new from eBay!
Thanks for all your reply's. :think:
if the wobble isnt steering, where are you feeling it? is it a general vehicle wobble, or something specific
The whole car wobbles but only slightly atmo! Some has suggested it could be a tyre wall?
