interior light bulbs
if changing interior light bulbs and tail light to led type for a brighter/whiter light, do they have to be a certain type ie canbus or not ?
does not matter tbh but for the difference in cost id go for canbus led`s
interior lights aren't monitored by the CanBus system AFAIK.
Do you know if the rear number plate light is monitored ?
I don't think so, no.
Number plate lights are monitored. But everything can be disabled VERY easily via VCDs.
Thanks guys. Canbus it is for n/plate then
One last question b4 I buy. Do you know the length of the middle bulb the barrel type (T10 w5w) I think
i replaced mine with led lamps in the First few days of ownership and no error on the display
Funny, mine came with a bulb out after changing to LED. Removed the check box in VCDs to check the plate lights and now everything is OK.
