Montreal II skoda badge?
Does anyone know if there's a Skoda wheel badge that would fit a set of Montreal IIs? All I can find are VW badges or BBS badges!
1314786391_245629959_1-Fotos-de--Jantes-
look up pastyboy on here, he does stickers for the centres (by sticker I mean quality ones), you can pick from various designs on submit your own.
Check out his latest group buy, donno if you are in time for this one but it's never usually too long between them.
http://www.briskoda.net/forums/topic/300652-pasty-badge-group-buy-10/
Happy hunthing.
John.
Measure the hole and then it will be easier for someone to tell you what Centre Cap fits that wheel.
I am quite sure there are Skoda ones that will fit.
All Skoda wheel Centre caps are available someplace to buy, they are readily available for modern cars.
Skoda caps will fit by the look of the size
Thanks for all the replies! I've measured one of the vw caps, and its 55mm diameter on the face, 52mm across the tabs, and the tabs are around 6mm high. Would that be similar to OE Skoda ones?
Yes
Mk 1 octavia caps should fit
Sent from my GT-I9505 using Tapatalk
that's brilliant - thanks all :)
