help with buying battery
the battery in my octavia mk2 2006 is bad so i was on the junk yard a find a fresh and almost new vw battery it was AGM 68 ah , in mine car it is a 60 ah , does it plays the major role ?
if your car didn't have an AGM battery as standard, don't fit one .
Would there be a problem with the different type of battery?
I got a Bosch S5 096 battery for my 2010 VRS CR. Its been great.
Another vote here for the Bosch S5.
Shipping to Sweden might up that price a tad. :( But I agree about buying Varta or Bosch.
I was referring to the type of battery not the make, nothing wrong with a Bosh.
Skoda tend to be a bit tight when fitting batteries to their cars-they use lower capacity ones than Seat. SWMBO's 1.9pd Altea has a 72ah battery in it which is still going strong after 7 years so as long as its the correct type and will physically fit there's no problem fitting a higher capcity battery when the OE one dies.
There is nothing wrong with fitting an agm or gel battery if your car has a lead acid one as standard.
I didnt have an agm battery but now im running 2 xs power agm batteries without a single issue
...There is nothing wrong with fitting an agm or gel battery if your car has a lead acid one as standard...
+1 with one priviso. If the battery is DEEP discharged, you will shorten it's life if you don't charge it with a smart battery charger before using it again.
Yes I realised that but whats the problem with the AGM type??
There isnt one
Donnt get me wrong but Bosh is not on that good reputation like few years ago...
I changed on my VRS last year stock battery with Excide Premium (think it is 74 Ah). Fitted perfectly and runs like a gun ;)
