New owner of skoda 120L
Hi All,
My name is Tihomir and I am coming from Zagreb in Croatia. I am the owner of estelle for 2 months for now.
It has 33000 miles on the dash. When i got her the engine was in bad shape. It was smoking, consuming 8-9 liters per 100 kilemeters and drinking oil. I am a student and my car is daily driven so consumption is very big thing for me. I decided to put in a felicia 1.3 MPI engine with rapid 5 speed gearbox. I have replaced oil seals and bearings in gearbox. The front end is lowered and restored with all new parts. The front hubs are drilled to 4x100 with 57.1 centar hole, and at the back are adapter plates.  Here are some pictures of a car.
When i got her
1292287_10201353461052828_1018887043_o.j
Mpi engine inside
1417663_10201505248967431_1268373784_o.j
Parts
10255223_10202724256481857_1770721333_n.
1921078_10202315749429436_862084897_o.jp
One with friends coupe 110r
1925024_10202456359824608_1650841450_n.j
And the wheels that are going to skoda. Just need to paint the center of rims in gray. Rims are Smoor Roadster 13x7j
11911_10202675723948574_8258280108701289
This is for now all but il will put some more photos if you want.  And sorry for my bad english. :blush:
Edited by Soljan
Looks amazing!
Sent from my C6603 using Tapatalk
Brilliant work I must say, very impressive. I hope you have many happy miles together :-)
What size tyres are you planning on fitting? UK specs normally used 165R13 on a 5.5J wheel.
A 165 is more stretch than I'd like on a 7J. I'd suggest using 185/70R13, but I think you'd get problems with aquaplaning http://en.wikipedia.org/wiki/Aquaplaning given how light the Estelle front end is.
I am planning to stretch 175/60 13 tyre on. I shouldn't have problems with aquaplaning because i am planning to move gas tank up front where spare tyre is and battery on front to even the weight. And the biggest reason is that i am a Slow driver. :rofl:
Check the standard size; one of the reasons that the UK went from 165R13 to 185/70R13 was that the rolling radius was the same, so the gearing remained correct. You've said that one of your concerns is fuel use, and a 175/60R13s will reduce the rolling radius, hence the overall gearing, so you'll need to rev the engine higher at a given road speed and that's likely to burn more fuel.
New rims. :)  16" and 8 Inch with 215/40/16 tyres at the moment
1553476_10203397968263927_4139542875840210275399_10203397969543959_561035575954510269137_10203397969903968_4282253315992
Edited by Soljan
I'm not 100% sold on the red wheel webs, but it's your car (and if I did buy it, the red is a good undercoat for gold), and the wheel/tyre size combination fills out the arches nicely. I take it the suspension is dropped a bit?
Looks smart!
I am guessing that it has no suspension travel at all as the wheels don't fit inside the arches?
