bam manifold conversion?
just got a bam manifold cheap off an audi tt with no throttle body.
what do I need to convert it to work on my auq engine? I will be putting a fmic on aswell
the part number for the manifold is 06A 133 223BP
hopefully this will fit my car
Extend the wiring loom to stretch over.
You don't need to extend the loom, you just need to unpeel the taped bit and unclip the plasticky trunking then reposition it, it's quite tricky but better than chopping and extending the loom.
the brake servo vacuum port is in a different place so you will need to adapt that hose a bit to fit.
if I recall there is 3 small vacuum ports underneath so you will need to block one off.
I have just done this like said wires don't need extending just peel the tape off and you'll find they're all the correct length... Are you doing this for a fmic?
yeah I will be doing this for the fmic
What benefit do you get from this mod? Is it worth doing?
getting the pipes down from the new throttle body position can be an issue i couldn't refit my battery tray without more alterations
that wont bother me as I enjoy doing fabrication
Yhep it's always the pipework that causes headaches.. You should see the trouble I had to go to on my felicia to plumb in a fmic, especially on a vehicle that was never designed to be turbocharged. Bleeding nightmare I tell you.
Think volvomeg did this, might worth P.M-ing him,
Cough*
Looks nice! You can use the same throttle body, right? Does the OE AUQ fuel rail fit ok?
Yeah can use same throttle body but you need BAM fuel rail as the AUQ one doesn't fit,
You also need BAM brake vac hose and a length of 8mm fuel hose and 2 joiners for charcoal cansister pipework and coolent hose that runs over manifold on fuel rail, also some 3mm vac hose for dump valve and fuel pressure regulator,
You will need bam manifold support bracket and bolts and a shorter bolt for behind alternator where you remove the original mounting bracket from, same as the other 4 bolts i think from memory or you can just cut it down and refit,
You don't need to cut any wires just open loom up and move wires about as required and them tape back up
auq fuel rail does fit as mine does
  • 2 months later...
Did you have to make any alterations to it or just straight fit?
Also what alterations did you need to do to get the pipework from the inlet manifold to the fmic?
I have the entire set up on my tt I'm breaking if anyone wants to do this conversion :)
Is the cost worth the gains? I've been eyeing up BAM injectors and MAF at the moment, some prices are stupid
Depends if you want to run an fmic I guess.
Injectors will have no benefit unless pushing power and will need to be mapped in before running them.
Not sure about the MAF? I guess 80mm helps intake diameter.
The larger MAF and injectors should see up to about 250hp when mapped. Without them you'll probably only see about 225-230
Mines running 220bhp on current setup but is only mapped to stage one altho everything is done for two but never bothered,
Mines still running standard turbo to maf pipe though aswell, never got round to changing it,
Its enough power for me through front wheels
Look at my project thread to see pipe work, auq fuel rail is straight fit but if you want to use bam charge pipe then you need bam fuel rail as auq rail fowls the charge pipe
