Dump valve?
Hi guys....just one question.I have a Ocatvia Vrs 2003 180bhp and i want to fit a Dump valve....I have read on the forum that you need a proper one to make the famous noise....
Does anyone know which one should i buy(the louder the better)
i have found these ones on ebay..any good?
http://www.ebay.co.uk/itm/SKODA-Octavia-RS-VRS-20v-Turbo-BAILEY-FITTING-KIT-AND-FSE-ADJUSTABLE-DUMP-VALVE-/181059229635?pt=UK_CarsParts_Vehicles_CarParts_SM&hash=item2a27f897c3
http://www.ebay.co.uk/itm/Forge-Splitter-Recirculating-BOV-Dump-Valve-for-1-8-VAG-/350248698969?pt=UK_CarsParts_Vehicles_CarParts_SM&fits=Car+Make%3ASkoda&hash=item518c730459
You would need the forge one out of those two, needs to be a recirculating valve.
Edited by JackRS1
or does anybody know where i can buy a better one ,but not ebay
Keep a eye on the facebook vag pages
People r always taking the split r valves of bud
Forge 007P along with an induction kit will get you the noise you're after and as it's a recirculating valve it won't break your engine.
Please stop right now
Do not buy a chav tastic blow off innit valve.
You will look a plank
Listen to the forum's advice and buy a RECIRCULATING diverter valve as thats whats designed for your engine.
The 1.8t does not run correctly with a 'blow off boy racer valve'
Forge are about the best you can buy. The 007p is what you want. Team that up with an open cone filter / carbonio and you will get a decent indiction note and the right amount of tssch so that it sounds half decent and not like a wet fart
ok guys i will buy the 007p....but where can i find a decent CAI that it s not no expensive
reversed forge 007p....what it s this about?......on some forums i read that you can reverse the 007p??
No it sounds like a badly owl
You can get an ebay CAI for not much money. Then just buy a decent filter for the end of it.
Agree with this, if you want to keep cost down get S2000 filter from the likes of ECP, or spend a bit more and get K&N or similar
Sorry to jump on this thread, but I've got a baileys cold side dv and fitting kit to install has anybody got one fitted or know much about them?
/\ sell it and buy the correct 'diverter valve' for your car unless you want to run like a bag of bolts
