Mk1 Vrs fitting 2nd hand cruise control
I'm currently breaking a Vrs that has cruise control and was wondering what I need to remove from the car to get it to work on my other Vrs I've got vag com so should be able to activate the ecu once every thing it need is fitted any help or info would be great
Believe the guys at Awesome GTI sell it, so they would be the people to ask for a bit of advice.
Not sure they would want to just give info out
Someone just added my guide if you reverse that should help you work out what to keep. It is quite complex and you might be better off just removing main stalk and loom to relay box. As you will have to locate wires in ECU and remove them. Basically it is get to ECU, relay panel and remove stalk and stalk loom
Sent from my XT1032 using Tapatalk
