Techy DPF info
Looks as if we should start changing over to a petrol engine now, with the news today, an extra £10.00 to enter London, Birmingham and Leeds, in a few years. So diesel cars will cost a lot more to
run me thinks..
  • Replies 79
  • Views 9.3k
  • muddyboots
    muddyboots
    You'd probably do well to have a poke round the VCDS forum on here ( http://www.briskoda.net/forums/forum/23-diagnostics-vcds/ ). Also have a look at the RossTech site to what VCDS can do ( http://ww
  • muddyboots
    muddyboots
    Logged well over an hours worth of data tonight, over 40-odd miles. Right mix of roads, starting with urban crawl, followed by giving it some beans, and then some steady A-road cruising. Logged the me
  • The training guide for CR 2.0: http://www.natef.org/NATEF/media/NATEFMedia/VW%20Files/2-0-TDI-SSP.pdf - this is the US version so I think the DPF portion should be the same as your car but there may b
Where are those places?
you must me mad to want to drive into central london anyway.
Muddyboots, while you are in the DPF frame of mind, would you try the effects of running on premium diesel
and comparing them to your "normal" diesel results.
On my Ford Focus 1.8TDCi using almost exclusively premium diesel the emmissions level dropped year on year.
according to my MOT results.
I am running a Yeti 2.0 110 Elegance at the moment.
Edited by gumdrop
Bit of an update...
Been keeping an eye on the mileages at which active regens have occurred, and it's generally every 200-250 miles.
Normal driving tends to be closer to 250 miles, hard driving brings it down around 200 miles, or occasionally slightly less.
As I drive around 400-450 miles per week, that's roughly 2 per week.
Would be good to know if this is similar to other, standard CR170 Yetis ?
However I suspect because the process is so unobtrusive, perhaps a lot of people won't really notice.
I tend to drive the same route every day to/from work, and there are usually 2 or 3 stretches where it begins; I can usually predict which day it'll happen so my ears listen out for the slight change in exhaust note (most noticeable around 1500rpm) and slight increase in idle speed.
