CH/LH lights
Hi all, is this possible on my MY12 Octavia VRS TDI? I don't have auto lights. I have tried coding it with VCDS but it still doesn't work?
Many thanks.
Sent from my iPad using Tapatalk HD
Without auto lights Leaving home won't work - irrelevant of the coding.
Coming home - after coding you will need to flash the high beam once with the keys out of the ignition, this will activate the C/H lights. (you need to do this every time which is why I didn't bother)
Once you open the door whichever lights you have set as C/H (fog or dipped beam) will illuminate
Edited by xpower
Every time? Wow, not really worth it then. Why is nothing ever simple?
Thanks for the reply.
