Rear door problems
Evenin all !
I've got gremlins in the n/s/r door I'm sure !!
It's deadlocked and won't open so I thought prob door lock but the window will not work off the drivers control switch but will off the door itself ?
Just wondering what's common to fail and where I should be looking first as I've gotta get it right to sell her :(
The wires where they pass through the gator into the door, or the control unit which is part of the window mechanism.
Our Leon has a sticky lock sometimes and you have to give the door a thump as you unlock it to free up the mechanism.
Do a search plenty of similar threads on here.
door loom on drivers door? where it passes through to the car...
Right gonna have a go at it today before work just to make it more interesting with the door in question , the window won't go up it down off the drivers switch so problem might be with the drivers door electrics . However without the keys in the ignition I can operate the window off the door itself ??
So I'm thinking of the door electrics are "live" all the time is this why the lock won't disengage and the battery goes flat if left for a week or so ?
And am I right in thinking the rear doors get there power from the front doors ? If so if I disconnect the nsf hopefully the lock will release so I can open it and save damaging the nsr door card ?
