Brakes staying on
Hi there, after having my Octavia estate come home from the MOT station requiring new rear brake pipe assemblies & a new front to OSR pipe, I set about replacing including making up the new pipe.
Bleeding took a while & in the end I had to get a pressure bleed system as the kids were getting fed up pumping the pedal!
I now have good firm pedal but the pressure is staying on, all 4 wheels are locked solid
I have had the master cylinder off & checked over by a mechanic but he could find no problem.
Getting beyond funny as without the car I have to get the bus & for a 7:30 start I have to get the 5:45 bus into town :(
The only thing that would keep all the brakes firmly ON would be the brake fluid pressure release mechanism in the master-cylinder, not releasing the pressure from the brakes, back into the master-cylinder...
Check pedal attachment to master brake-cylinder for correct positioning.
I thought bleeding by pumping the pedal was very bad for VAG cars as it will wreck the seals in the master cylinder?
I have tried pulling the master cylinder away from the servo as a way to check this is not happening, No difference
I have even tried pulling the fuse for the ABS/ESP but still my brakes are still locked solid, the system is getting a good pressure test anyway
not been using mole grips to seal off flexible pipes??
Update
went back to basics, I managed to get fronts moving readily enough, just the surface rust from sitting idle for a few days impeding motion,
the backs on the other hand not so much.
nemesis thy name is oxidation
removed OSR calliper & found the pads were sticking due to rust under the slider plates, also having a close look at the calliper it is quite a bad way, aluminium is not a metal, it's a fungus
looks like a pair of callipers is on tomorrows shopping list
If you bled the brakes by pumping the pedal you can smash the actuator rod through a metal plate at the back of the servo, which locks the brakes on because the rod can't return.
I now know of 4 cars that have had the same problem, mine included.
Unfortunately the only way to solve it is a new servo, they're not cheap and an absolute bi**h to change.
this would appear to be the problem, I am now going away to blub like a baby :(
