Number plate fixing grommet
Does anyone know the part number for the little white plastic grommet that pushes into the number plate fixing hole on the boot so you can screw the number plate on. Mine has broken and just spins around so I am unable to tighten up the number plate.
Thanks.
If you try to pull the numberplate out from the boot in the same time as you try to screw, it may fasten.
Worked on mine when i had the same problem.
Edited by ahaavi
Stick the plate on, looks much better.  :)
Yep. My dealer always uses double sided tape
I am sure the dealer who sold you the car will give you a replacement if you ask.
Part no. N103 18 001. Thanks to Andy at Simpsons Skoda last week! Managed to get 4 @ TPS in Stockton. £0.18 + vat from memory.
Edited by Black_Sheep
