Anti hijack locking
I can only presume thats whats been enabled in my octy.
As i set of and get over 10/15mph it locks the doors, as expected.
But it randomly unlocks and when slowing down below 10/15 which would surely be pointless?
It is dodgy or has something else been enabled too?
Not sure but when I enabled it on mine there was another tick I had to add for the unlock when taking the key out, so maybe that has been missed as mine works as normal and only unlocks when I take the key out
John
It shouldn't randomly unlock so something is amiss there!
Sounds like a safety issue too.  Should be 'clunk, click, every trip' (as ex-saint J**** S****** used to tell us), not 'clunk, click, un-clunk every trip'
Sounds like exactly the same as the problem I had with the car.
Took it back to the dealer as it was still under warranty and they identified it as a faulty ignition switch.
Replaced it and problem solved!
Other symptoms we had were flickering dash lights while sat with the ignition off and sidelights on.
Phil
Ah, i dont have any other issues.
Just turn it off i think.
Its as if its set for above 15mph. Anything less it unlocks.
There's definitely a fault as you can't set it to unlock again when you go under the speed.
It should stay locked until you remove the key from the ignition.
If it is a faulty switch it should show a code on a scan.
It could also be a dodgy door switch.
Phil
Taxi? :D
Getting a remap tuesday so will get it scanned then and see. Hopefully just something simple.
