Spark Plug Gap
Have a 85PS petrol Fabia, 2013 model.  Great little engine.  What is the correct spark plug gap for this engine please?  Thank you.
Anyone?
From what I remember they are all preset as I cannot find any gaps as all sites just say preset!
Tsi spark plugs are modern platinum and/or irdium fine tip types that last much longer than old copper designs. They are preset and cannot be adjusted. If you attempt to adjust them they will break. In general the gap should stay constant throughout its life, but the central tip becomes worn/rounded with age, which increases the initial discharge voltage and the likelyhood of misfiring. 0.8mm is the standard gap for the plugs fitted to the cbza engine.
0 242 240 665 - Spark plug, Iridium
Spark plug, Iridium - Part number 0 242 240 665 - Designation Spark plug, Iridium - Production discontinuation - - Type formula FR 6 HI 332 - Electrode gap 0,80 mm - Connection type DIN/SAE-Kopf unlösbar - Thread diameter M 14 mm - Diameter_center electrode 0,8 mm - Spark position 7 mm - Thread length 19,0 mm - Tightening torque 28 N/m - Tightening angle 90 ° - Thread pitch 1,25 mm - Width across flats 16,0 mm - Interfer. supp./burn-off res. 6 kOhm - Center electrode core material NiY + Cu + Ir - Center electrode material Ir - Ground electrode material NiY + Cu + Pt - Sealing seat Flach - Number_ground electrodes 1
http://www.bosch-automotive-catalog.com/public/catalog/products?p_p_id=BoschWSRP&p_p_lifecycle=1&p_p_state=normal&p_p_mode=view&p_p_col_id=column-1&p_p_col_count=1&_BoschWSRP_wsrp-urlType=blockingAction&_BoschWSRP_wsrp-navigationalState=%2FWFS%2FAAGLOBAL-AA-Catalog-Site%2Fen_DE%2F-%2FEUR%2FViewSearchProduct-Detail%3Bpgid%3D794ED988765255402A198E3C2302CO24qbwc%3Bsid%3DXz8_v7ukWzHSr-g0sF6zRbQvlAFcf5sLnNhu4xkc0Zoi95sLnNj0gdhk&_BoschWSRP_proxyportlet-remoteInvocation=true&WT.pn_sku=0242240665&wti_ecat_eqProductDetail=1
Edited by xman
