1.4 16v Crank pulley bolt.
Morning all,
Quick question - going to change timing belt, tensioners etc on my new to me Fabia.
It's a 1.4 16v AUB engine.
Reading various guides - but some confusion on one point.
Crank Pulley Bolt - is it a "one use" item or reusable - and if one use whats the part number so I can get one in advance.
Cheers, James
Crank Pulley bolt is One time use, replace with new one.
Torque to 90 Nm then a further quarter turn.
Many thanks for the response - will try and find one before I pull it apart.
( if anyone has the part number much appreciated)
  • Sponsor
Item 7 here by the looks of it, but be careful to pick the right one, it appears to have changed length twice.  This thread may well help you to understand how to turn bits of your VIN into the info you need to understand the chassis number ranges in the 3rd column.
Will (probably) be much quicker and easier to just phone Skoda and ask for it.
Thanks for that - though I think my brain just exploded as my VIN does not look to meet the required format!! LOL!
Cheers all! :)
