Back doors not unlocking and remote control not working either
Hello,
I have an issue with my Skoda Mk2. The remote control is not working at all. I see the light blinking when I press the buttons but I get no response from the vehicle. Is not locking or unlocking, also the back doors are not unlocking and therefore are not opening.
I had this problem with mine awhile ago. If you use your key to unlock/lock the drivers door it should start working again. Mine went out of sync for some reason.As soon as i manually locked the car with the key it started working again.
Hello again
I have tried this with no success. the back doors wont unlock even if i try unlocking them manually with the key. The vehicle still not responding to the remote commands and the backdoors appear to be sealed.
New issue: now all 4 turn signal lights are on and steady. They won’t turn off even if the car is off and locked.
Anybody?
Tried to disconnet the battery so the system does a "reboot" ? :)
Alsomme
PS. Make sure you have the radio code in case it must be entered :)
Alsomme
thanks for the reply..
I am very sad to inform this did not work. Still having same issue.
How long time did you have the battery disconnected? I would leave it for a good while. There could be some capasitators?? that remembers some settings if the battery is disconnected for just a short time.
Alsomme
I am not a car electric specialist :) but in my house i have some heater ovens that remembers my settings for ca 6-8 hours if the power goes down
Alsomme
