Octavia Air Con: Fault Code 00819 High Pressure Sensor (G65)
The air conditioning on my 2005 Octavia FSI Estate isn't working. Garage has re-gassed and detected a fault code of "00819 - High Pressure Sensor (G65) / 009 - Open or Short to Ground".
However when the switch is bypassed the air con still doesn't work implying it may not be the sensor.
Has anyone seen a similar problem?
Only option seems to be to try replacing the sensor to at least eliminate this as the cause. Help appreciated.
