Saikou Michi Oil catch can
Where's the cheapest place to get this catch can. Its over £100 on ebay.
£100 is prob about rite mate
When i was doing group buys i think it was slowly getting up to £100 fully delivered
All be it that was with the level site and your choice of colours
Even bare no level basic blacks came in about £90 if there was 5 cans on orders
Good cans tho bud and actually have innards so not just a empty can
Ok mate cheers. Ill have to just bite the bullet then lol. Wheres best to get this 19mm special silicon hoses?
I can only seem to find it in blue. Ideally id like black so it looks oem
Edited...
Iv found a kit on ebay. 2m 19mm black hose with a T piece a L piece and 4 hose clips. Im guessing ill need a few more hose clips tho.
Edited by P34RC3
Iirc its about 2 clips bud
2x1m lengths of fuel/oil 19mm id hose
1x 19mm barbed tee
1x 19mm barbed straight connector
Michi will send u 1 but unsure on a single cost, plus customs on ur own could suck
Ive done 4 michi buys i think now
But id need 4-6 guys
That is for it going here on a mk1 vrs
00000000-0000-0000-0000-0000000026AC_zps
1x 19mm barbed tee
1x 19mm barbed elbow
Whats the elbow used for? Who or what is michi lol? He a seller of the catch cans or something?
Saikou michi is who makes the can
The elbow is a straight :D i goofed ha ha
The straight u trim down and it pushes in to the lower breather pipe
I dealt with mr michi michi direct :D
Its the shipping and customs risk that nail you for 1 tho :(
I dont need that straight because iv removed the T bit it would of gone on to so I just pipe straight off the elbow under there.
I take it u have bonnet lifters. Iv got the clip for my bonnet prop in the way lol.
Theres 3 holes along there u could use bud,
The straight goes into the one at the bottom of the engine
Mark bowders got a fitting guide for the michi too
Not sure on deletes but the catch can basically goes to the 19mm vac
Not the thinner stuff bud
On that pic, marks catch can is the blue fat hose coming from rocker cover
The straight conector goes to the connection down at the base of the engine at the front bud
But doesn't the 19mm pipe just go over the elbow at the front of the block. Thats how it looks from the pic.
Look at the 9th and 10th pics
Edited by P34RC3
The 19mm comes from the hockey puck type valve ( next to diverter )
The 19mm pipe goes from that to the can
The other outlet goes to the TEE
WHICH
1 bit goes to the rocker cover
The other goes down and toward the bottom of the block mate
Catch can goes on the turquoise line
Yh the bit that joins the bottom of the T connects to the bit near the block. Because iv removed the T bit down there I can go straight onto the elbow like in pic 10. I think anyway its getting well confusing.
Sorry to crash your thread and hope you don't mind but rather than start a new one I though I'd ask the question here first as it's to do with the delete.
basically I've done all the deletes as I had various pipes split and just wanted to check if I can do this?
At the moment I don't want to fit a catch can as I'm lazy and can't be bothered to empty it so for now am I ok going from the 90 elbow off the oil filter housing with 19mm hose and connect into the empty location on the silicone y pipe I already have?
So it will be,rocker breather into silicone y pipe and into hockey puck as it is standard and then a new 19mm hose from the elbow on oil filter housing up to the now empty port of the y pipe and cap off the two spare inlet manifold tails underneath?
Can't see any reason why not as it would be similar to standard? but thought I'd ask and if I eventually decide to fit a catch can I'll just do it as per the guide.
Yeah :D
Without seeing the engine hehe
So guy on ebay selling the catch can hasbt got any for another 2-5weeks. Should I just contact them directly? Or is there another place I can try?
I dont know of any place who does them, sounds like ebay dude orders them and they get shipped to order
It was about a month turn around i think when i did them
Worth a email bud, its the int shipping that sucks for 1 can
I will pop him a email too if u want as i ended up on a good discount :)
