Bmw wheels on Mk1 VRS
Then contact these guys to sort ur front lips out
http://www.archenemy.co.uk
Rears u also could go with some camber ;)
-1 camber shims will knock the top of ur tyre in a good 8-10mm ish id say
All helps :)
Might just get the backs on as they are as you can just about squeeze nines under them but will have to run camber on the front good job fitted TT bits up front. What are they like grip wise? Drove a mates on nankangs and they felt a bit loose and didn't offer as much grip as say a set of avons
Its more of a no choice if u want stuff to fit bud
They arnt bad tbh, got on the zaf thats 209bhp 307lbs now
Rear wise, yeah they take 9s and i have 9.5
But..... I have camber and also they have the width to pull a stretch
A 8j rim that aggresive sitting will have tyre rite where u dont want it but
Them as-1s narrow in at the top like a stretch
Thing is wide or poke or flush or low or such doesnt always go hand in hand with traction and drive
More so u go with what fits
Say -1 degree rear shims for camber ( + toe correct shims as needed )
Stretched or narrow tyres to avoid arch munching
True but don't want to have fook all grip either if I choose to drive it hard. I have got the beam relocate plates to fit to shove it back to where it needs to be and all arches are flat with no edges to help clearance. And agree don't want arch munching but at same time don't want a stupid stretch on the tyres if can avoid it. So think 215 would be a in between thing. And I don't intend to run it that low just sitting above the tyre is where I'm aiming at
205 wont be a stretch on on a 8 bud
Just gona have to be ur trial bud :(
Its a hell of a offset to dance with
What if u purchased 1 tyre and tried it on front n rear to see how fits
On the rear the beams are usually a tad offset too, so try it on rear passengers side as its usually the 1 thats a few mm further out bud
If u were gona try a 215 u could try a 215/35/18 maybe?
This I've got to see. Et5 or et10 is asking for trouble and will poke like a good one, if you don't run stretch you'll not get the tread in the arch which'll render them illegal.
Maybe get the arches rolled & flared to help a little.
The octavias arches are nowhere near as forgiving as the mk4/mk5 golfs are:(
Edited by SNH
So et5 will have the face 11mm further poke than my 9.5s i have on the rear
Nothing is impossible yes I get it the reality of it makes it seem not but I ain't been defeated yet. Did consider a 215 35 to help a touch as they say go big or go home. And don't know about the unforgiving part only becomes a issue when you run your car so low it's not possi
Defo rek you will need to look at rear camber ;)
This is -1 camber shims
Ur faces will sit 11mm further out
E951F59B-EB24-4AA2-B83E-F3C79C1AD324_zps
But if your not prepared to run stretch or camber it's gonna look ****!
To get them to sit right is not going to be an easy task tbh, but if your prepared then go for it.
