Mk 1 vRS Front Brake Pads
A quick question - does the vRS have front brake pad wear sensors? A part number would be good if anyone has it to hand?
Mine doesnt, but mines a plain 53 Reg VRS & not a VRS SE.
No, no mk1 Fabia in any spec has electronic brake pad wear indicators.
Many thanks I thought that was the case. They should be cheaper then :)
Fabia's that are on variable servicing do have wear sensors. This is because it can be up to 2 years (20k miles) between services when they are inspected. However I don't think the mk1 Fabia vRS was ever fitted with variable servicing only fixed (annually/10k).
It doesn't matter if the pads come with the wire, all you do is cut it off
As said, no mk1 fabia has wear indicators.
I know you did. I was led to believe some non-vRS's did.
It doesn't matter to the OP as he has a vRS and I wouldn't think the SE will be any different. The only difference with the SE,  the callipers are painted red, not green.
Edited by Jim H
