Headlamp replacement
I need to replace the n/s (passenger side) headlamp unit on my Mk1 Octavia estate and was hoping to find some advice on how to do so on this forum. But I can't find anything ! Grateful if someone could point me in the right direction.
2 minute job:
- Unbolt the indicator (1 bolt), twist the bulb holder out and pull the casing off the vehicle.
- Unbolt headlight (3 bolts), un-clip wiring, pull casing off the vehicle.
Simply reverse the procedure to re-fit ;)
Many thanks Tactical 87 - sounds fairly straight forward. I shall find out tomorrow.
Theres a sneaky 4th bolt near where the indicator sat which is fiddly so watch out for that one.
The wiring harness connector.  Use a flat screwdriver on this and 'lift' the tab towards the windscreen to release it, i.e. away from you if youre stood at the front of the car
And my thanks also go to Liverpool- Lad for the additional info. :sun:
Plus as your car is pre-facelife, make sure the replacement unit is from a pre-fl vehicle too, as the headlight shape changed.
