B&M shortshifter fitted
Fitted a B&M short shifter today after searching for a few years with nothing listed at all for a Fabia
Opening the box it has precise instructions, not all are relevant to the Fabia as they are for a Golf
First impressions it's a quality looking item that is very well machined
1dc111cd65873f7009dba677ddbcc733_zpsf5bb
Lined up against the original shifter
9b498449e25e04d29299aaddd4693b4c_zpsfd9e
Old one removed
9c6bd5b40c6f4fafe44e8b5b035179e4_zpsc388
And fitted
9786cc2e31c5faaf74776bcc9d7d264a_zpsb530
3741a2c84f4d73ef19805c0b41bb7954_zpscb79
fa63b5951ff59d0adb3d0b3c9663314d_zps3c9e
The first noticeable difference is that you have to lift the shifter to get it into reverse instead of pushing down on it.
Test drive has to wait til tomorrow as I've re bonded some parts of the grille so waiting for the tiger seal to dry
  • Replies 74
  • Views 8.7k
Do you have to use their gear knob? Looks short! Which could be annoying as I have arm rest fitted.
Get a bit more thread welded on?
So far as I can tell yes. It screws on
Would kind of defeat the object of the short shifter :D
Yeah I realised saying that afterwards
Looks smart though!
Do you think it would be the same if the standard shifter was cut down as done previously on here? :)
Quite possibly. I'll have a good play tomorrow and update :)
B&M usaully alter the shift point on the lever to make it a quick shift rather than just making them shorter.
It might be short cause its for a golf?
Possibly. Should improve shift throws though :)
A bit off topic but what steering wheel is that ? And do you have a full pic of it ? Cheers.
This looks really good where did you source it? Look forward to the review :)
It's a custom re-trimmed R32 wheel, it's very smart!!
Jabba sport I think mate. Equally looking forward to the review! :)
So is this designed to alter the shift point making the gear change shorter or just shortening the height of the lever? I'll look forward to the review
It's designed to make the gear shift shorter and quicker :)
As Dan says its a custom re trimmed r32 wheel
Only have a really old picture
4d4a21e2f470522d63e8c638cd499d1e_zps0b8b
Driven it yet?
Nope, just come home for lunch. Won't drive it until 6 ish this evening
Lol
No way, I sold my b&m off my octavia vRS for peanuts. Wish ide held on to it now as it was an awesome bit of kit. Changes were so solid. Felt more like my M5 does.
It really does give you confidence. Unlike the wollowy flappy std setup.
Have you got a link for the short shifter
This is my B&M short shifter. Had it for nearly 6 years now.
Gives a more precise and crisper gear change.
I've tried to find a cheap eBay copy cat there's a few listed for Octavia's etc for about £30!
But they are all lift up reverse
However! The ones I've seen on eBay are for the cars mentioned in the one from Jabbasport apart from there's no mention of Fabia on eBay.
Charlie is the B&M one now lift up reverse?
