Few questions about 1.9 tdi mk2
I ran a K&N panel filter for a while, as above never noticed any real difference over standard
  • Replies 128
  • Views 8.9k
  • Congrats on getting a 1.9 PD.  Lovely motor.   Usual symptoms of low/worn gearbox oil are notchy or baulky changes into first or when cold, so the problems with third might be a synchro thing, but f
  • Thanks for that here you go i took these the day i purchased the car so on monday i think, So far i have put a set of skoda vrs number plate holders on, bought xenon headlight kit however not fi
  • Looks very nice, and I like the plate as well
If you have some flat and level ground, try rolling the car by pushing it. It should be easy to get it to roll. If not then an investigation will be needed. Any scrapey graunchy noises need checking out too.
Any filter other than the VAG one will let through more dust.
I don't think anyone has been able to demonstrate real world noticeable performance increase using an aftermarket filter. Just sound a bit louder/different.
A whole CAI may raise a single HP.
Has anyone had there intake taken out an cleaned, heard they have alot of carbon build up, worth giving a clean along with the egr or give it a miss, my car doesnt smoke unless it given the beans and even then its just slightly
And i managed to average 49 mpg 2 days in a row much happier as the range doesnt wont to drop compared to when i was getting 43
Would anyone reccomed a remap company not to far from birmingham iv been looking at mpg tuning in cannok however has anyone had any good experiences else where
Not really intrested in figured just power delivery and mpg improvments if any
Oh and mph tuning has quoted me £195 for a custom remap and has alot of good reviews
Edited by DanialA11
Injector problems = PD170 on vRS models, and as Mike said, replaced for free.
Any idiot can cross thread a sump plug on any make car, probably due to not using a new one each time as you are supposed to.
No electric handbrakes on Skodas.
The 1.9PD is a bulletproof engine as long as you service it correctly, with the correct oil. Did you replace the fuel filter at this service as well, worth doing at each service for the £10 they cost.
Has anyone given you the bad news about DMFs yet LOL
Nope not yet, but some people have said when the dmf is on its way you should convert it to single?
Edited by DanialA11
I think a extra £40 for a custom remap would be better as tuning boxes have fixed map on them
Yep, on the 1.9 the SMF is a proven solution. Unless your clutch and flywheel have already been replaced I expect at 118k they aren't that far from needing doing. I find that around the 100-120k mark is when they normally need doing.
You might be lucky and it has already been done and you have another 80-100k before you have to worry about it :)
How would i find out if its been changed, it feels quite low to be fair any actuall ways to check
@mikeholroyd
That's youthful enthusiasm for you!
Soon be go faster stripes and furry dice with names on sunstrip ;-)
Not trying to be rude or disrespectful but after some of your questions and replies to answers given, would it not be wise to walk before you can run before thinking about remaps??? Get any issues with the car sorted out first, especially with clutch and flywheel before going down that route. Mike
When i got the sump changed i had the mechanic check the car and he told me one track rod end will need doing soon but apart from that everything else was good
Most the problems with the car was just tlc, e.g the gear box into 3rd gear after adjusting cables its now smooth as a babys bottom,
Inside lights were faulty however a friend of mine got a full breaker at his garage whicg i spent a day at swapping parts over
As said above im not intrested in power at all was mosty intrested in mpg as i know these engines can do great mpg and have heard of some doing outstanding after a eco map
However im not in any rush for a re map atm because my front bumper has got the ****test re spray in the world atm and i would rather have the car looking presentable before anything else.
@mikeholroyd
If u ever see me driving this with stripes or dice or a shopping list down the side, please stop me and give me a good old back hander
Edited by DanialA11
Could anyone tell me what mm bolts hold the undertray on and isit 10 i need ?
Think they are torx screws T25 and T30
So 10mm bolts wont do the job?
Don't know but the proper screws are not expensive from you local skoda dealer or TPS
As said definitely screws. On mine when I removed it recently to recover a dropped torch, there were nine and one missing, so ten it is.
No 10mm bolts won't do the job. As you've just been told they are torx 25 and 30 screws -- pointed end screws that go into speed clips in the side plastic pieces.
Mike
Only asked because i dont know the diffrence between the 2 apart from the bits that go into them
So there 10 altogether do i need 5 t25 and 5 t30 or ??
Sorry for all the questions but just dont wont to get the car on the jack, then drop it an hav to go auto spares because i have the wrong screws
They were all the same (T25s I think) in my case.
Thanks Mike. Looks like 11 then and mine have been replaced then at some point in the past as it was only one torx bit I needed.
Skoda do like to mix up their torx screws though. There are at least three different head sizes used in and around the dash area!
Just filled my screen wash bottle up, and the jets arnt squirting the water /:
its OK quoting T25, T30 for the screws, but surely this is just the size of the torx bit on the screw head, the screws you will need will be self tapping type and you could use another type apart from torx, as long as the screw head is big enough to hold the panel up.
Question to the OP, how do you get on with the insurance? someone stated that your car was an Ambiente before being a Cat D and then it seems it has had a vRS makeover when repaired. Do you inform the insurance of all the additional parts the car now has? or is it insured as a standard Ambiente?
I told them it was a cat d and they wonted a mot copy to prove it was road worthy, and i told them about the 'body kit' as they classed it and the alloys spolier and interior replacement and it was £400 cheaper then a standard octavia, happy days :)
Edited by DanialA11
Lads any advise, topped my washer bottle both front or rear jets are not working, was working a few days ago just randomly stopped,
Few days ago i had the rear plastic pop off on the rear under the boot cover but i connect that back up, didnt use for a few days and now nothing,
Any direction you can point me into please
Going to look like a complete idiot,
Basically when i was asking about the fuses not long ago, i took out all unnecessary fuses that were in un used places and put into a little bad in glove box and took out the fuse for the washers -.-
