building my engine
hi guys im putting my lump back together tonight could anyone plz tell me the torque setting for the big ends and pd150 head bolts? cheers
No idea on big ends but you need to do the headbolts from the middle to outside in stages 1) 40Nm 2) 60Nm 3) 90 degrees 4) 90 degrees.
The last 2 stages is best done with a long rigid bar, not a ratchet.
The big end bolts are also stretch bolts, this is why many people fit ARP bolts instead.
Here you go
30nm
90 degrees
From auto data
And main end if you need them
65nm
90 degrees
Here you go
30nm
90 degrees
From auto data
For the headbolts?  That doesn't correspond to my Skoda manual with says 40/60 and 2 x 90 degrees
He asked for big ends you already did head bolts
lump all together now head been reworked, newmans cams and followers, new water pump and timing belt just waiting on darkside before i can slap the sump back on and off to faboka for a sweet map!
