Suspected Crank speed sensor!
Hi all,
Just wondered if anyone could advise on cost and work involved to replace the crank speed sensor which I believe has failed.
Symptoms - engine ticking over highly (over 1000rmp), popping and running roughly when under heavy acceleration. Not starting properly and EPC light. Fault code in picture.
Thanks in advance!
IIRC someone did a fitting guide, not that expensive, but need to be careful tightening it up, DON'T overdo it.
Thanks Andy, I tried to search for one but not sure what it would be called !
Also known as Crank Angle sensor, can't find the fitting thread on here, so probably read it on another forum MKIV platform SCN, TTOC etc
Thanks Andy and DGW you have been most helpful, still in shock of how much they charge for a sensor!
