speed sensor/crankshaft sensor ????
got a problem with my vrs, vagcom is saying it's error code 16706 (g28 speed sensor) has anyone a clue where it is?
trouble i'm having is my car was having trouble starting, maybe 3 turns of the key to get started (epc light on). now it won't start at all after having the vagcom on. the yellow engine light is also now as well but the fault codes have all been cleared.
any help would be appreiceated.
Google got me -
Unplug the 3 pin connector for the engine speed sensor and
- Measure sensor resistance between terminals 2 + 3 of harness connector to sensor. Specified value: 480-1000
- Check sensor for short between terminals 1 + 2 as well as -1- + -3-.
I don't have time to check any more at the moment.
where is the speed sensor on the vrs?
cheers mark.
Front of the block behind the oil filter, the lead (grey one) comes up under the inlet manifold.
16706/P0322/000802 - Engine Speed Sensor (G28): No Signal
Possible Symptoms
Engine shuts off
Engine doesn't start
Speedometer inoperative
Glow Plug Indicator Lamp (K29) flashes
Possible Causes
Engine Speed Sensor (G28) loose
Engine Speed Sensor (G28) faulty
Possible Solutions
Check Engine Speed Sensor (G28)
Special Notes
The Engine Speed Sensor (G28) is also used as a reference sensor for the crankshaft position.
having a look now, see if i can find the connection near the inlet manifold, any idea how much a new sensor is?
About £70 iirc.
Possible Symptoms
Engine shuts off
Possible Causes
Possible Solutions
Special Notes
I tried to get that this morning but the Wiki didn't seem to want to load and I didn't have time.
can i eckers like find where the wire from the sensor goes, looks like my car is gonna get towed away to a garage this week and let someone who knows what there doing look at it :rolleyes:
Google got me -
managed to get the sensor off with the help of a crowbar :D prior to this i did the above tests and nothing what so ever, completely dead. anyway i ordered a new sensor through my local specialist and it should be with me tomorrow morning for the total sum of
Hi Mark,
I didn't see a Skoda when I collected the Lego ;)
Hopefully getting a Vrs in August so might be speaking to you about audio in a few months :P
Hi Mark,
hi twonks! you must be blind then, what did you see!! mine might be sale by then, not sure if i'm gonna keep it or sell it later on this year....
