Will these fit?
Hey guys,
Quick question as I'm no guru when it comes to wheels!
I've seen some 17's for sale, 8.5J fronts ET25 and 10j rears ET35, tyres are 215/45/17 and 235/40/17.
I have a mk1 fabia vrs, will they fit? I'm aware I may need to do some arch rolling etc, especially on the back!
Cheers!
Hey guys,
Cheers!
HTH
Model Year PCD Offset Bore
Fabia 00 on 5×100 30 to 45 57.1
I mean with regards to them being too wide, wanting to go down the euro route with things and have a bit of a poke, but will 10's on the back be TOO much poke?
Its the fronts id be concerned about mate.
clearence past the brakes on such a low offset wheel may be an issue.
front arches would need rolling if you want to go low.
You'd definitely need a different tire. .195/40/17 should do it.
biggest wheel ive seen on the rear of a fabia is 9.75j . . And you need lots of camber and lots of stretch to get them in the arches.
Thanks vrs'burks, that was the answer I was looking for. I guess i'll keep on the wheel hunt then, just saw some keskin KT1's at a ridiculously low price!
