Strange speedometer problem
On Superb 1.9TDI MY2010 speedometer is acting a little strange. It shows the correct speed, but the needle is constantly moving for cca. half a mm around the correct speed. So the speedo needle is not in place at any time but is dancing around :).
Has anybody else noticed this strange behavior? What could be the problem? In old days this would mean that speedo cable is stucking, but since now speedo gets the signal by wire, this should not be the case.
Similar problem HERE. No idea on a fix I'm afraid...
Thank you for pointing to other thread, I will continue there.
