more powaaa?
I should never have brought this car, im becoming obsessed with making it quicker.
Anyway, i just had a stage 2 done a got 221bhp and 266lbs torque on 97ron fuel
I have forge recerc valve
Panel filter
Turbo back exhaust 3" milltek
Forge fmic
Whats next ? Lol
Can i squeeze another 10-15 bhp from my pokey little k03s?
Diff next !
Supersize TIP
225 injectors
Walbro fuel pump
Supersize TIP
225 injectors
Walbro fuel pump
I've got that lot but instead of a Walbro pump, there's a Sytec drop-in replacement instead, as well as a ported exhaust manifold, as I'm not planning on changing the turbo, so an expensive manifold wasn't worth it for me. Oh, and a stiffer actuator if your one is getting old and weak. My car made 217bhp and 228lbft on R-tech's rollers without the N75 plugged in and only runs around 50% duty cycle at the moment. It needs to be mapped properly though, otherwise you'll get overshooting boost levels.
That's if you just want more power though. I'd think about the rest of the chassis first. More grunt in a straight line in the real world is fun however...
Forge fmic is a limiting factor
How so?
Doesnt flow aswell
Reckon ill get saving for a bigger turbo or hybrid
Id like to grt abiut 260bhp
Maybe go KO4 should see you to 260
No get your setup flowing well and a stage 2 can see 250bhp
Just have to put the right bits on all about flow
This means ive got to sell my forge intercooler and get a different one?
Nnnñnñnooòoooo
I fitted my boost gauge at long last today
Can anyone tell me if its normal gor my boost to hit 1.4bar and then drop off to 1bar and as your get closer to 7krpm it goes to 0.7bar? I always thought it would hold a constant boost? Im sure it used to in my old mk1 rs turbo
Look at a company called beach buggy turbos if you want about 250 ish mate that's what I have now just have to get the map checked now and mine does this as well goes to 1.5 bar then holds at 1.0 bar but I know that my intake cam is one tooth out so I have to fix that
This is what mine does almost, it gets up to 1.4 bar then gradually falls to about 0.6bar
http://m.youtube.com/watch?v=o-5wlzZF4bs
If i have an issue that i wqsnt told about when they mapped it ill be properly ****ed off
Boost leak? Actuator? Ill see iff i can get a video up
The ko3s cant hold its boost all the way to 7000rpm its supposed to tail off gradually
Awesome! My mind is at ease lol
Yeah its perfectly normal :)
Mine isn't a normal ko3s though it's a beach buggy turbo k250s which is a ko3s compressor wheel but an rs6 exhaust wheel and an uprated actuator rated to 10 psi
Harold do you have a picture of your exhaust by any chance mate ? I managed to get mine on the ramps the other day and the exhaust looks shocking
Have you had it remapped jimbling?
It had apparently already been stage 2 mapped by jabba Motorsport it's some ones project off here
Ill get a picture up for you mate, really happy with it, its got the perfect sound, not to loud but when you give ut some welly its got a great note to it, you can hear the turbo whistle from it
Was it a miltek ? Or a custom jobbie ?
Can you recommend to me the hardware i need to take it a bit further?
Jimbling, it a full miltek mate
Where did you get it from as I can't find a 3" miltek anywhere as the one that's on mine is SHOCKEN looks like Stevie wonder welded it together and from the turbo the only connection I have is where it joins to the back box
