tyre size question
They will bud
Even more with et32
On 3mm further out than the comon et35 but still
The rear beams tend to be offset too so you'll find you will get more issue on say, the rear n/s
So are you suggesting spacers or just change of tyre?
Defo dif tyre bud
Basically the lower the offset the further the rim sits out
Its all mm
So say a et25, that will sit 10mm further out the arch than a et35
The et32 will sit 3mm further out than than the et35
Not much, but then u have the width
Standard spider is iirc 7j, 18s are commonly 8j ( inches )
So a et35 8j already would be 12.5mm further out / and into the arch
If that makes sense :D
225/40/18 is used all over on 18s mate :)
Thanks i thought et 32 would have been less from the arch but it works the other way. Has cleared things up alot thank you
No probs bud :)
