Lowering
At the moment I've got AP coilovers with the adjusters out on the rear is there any other springs I can get which will sit lower without cutting as I'm looking to lower my car more
do you not have speedbumps. road cambers. pot holes where you live? :S
ait ride maybe your next step?
Edited by fletch101
Yeah but there all easily avoidable :) air is to un reliable for me and wanna go static lows
Anyone know of anything ?
Have you driven a stupidly low car for a prolonged period of time?
By adjuster out do you mean the adjuster ring is off. . Or the entire adjuster cup(threaded post). . Thats one way of getting lower.
Also removing the rubber topping off the spring,not sure itd be much good on the car though.
The whole adjuster is out just spring in with top rubber as wouldn't gain anything from taken it out, the only other thing is to cut springs or heat them up so they collapse
Sounds like the start of one of those compensation adverts :rofl:
when i had AP's I had the adjuster ring 1/2" from the top of the adjuster and that sat with about a 30mm arch gap, with the adjuster out that must be already silly low.
if you want to go much lower it will have to be on air.
Like Vrs bucks said remove the rubber at top of the spring I done that one mine and it does sit lower know
Air is to unreliable for a daily car, but I hate arch gap I will try taking the top rubber out see where that leaves me
Use mine daily. . Almost 2 years on air. .
It might have been unreliable a few years ago. . But with the airlift and accuair managment nowdays its easy to use.
Look at busses and lorrys,theyve been running air waaaaaaay longer than cars. . And are on the road more than personal cars too.
My brothers had a lot if problems with compressors and stuff
Top rubbers are out and will have to do but still not happy need more static lows :(
Get some custom rear springs made :)
