Retrofit electric windows
! Is it possible to transfer electric windows from a Fabia Classic (2004) to a 2000 /2001 Fabia classic? I've got all of the parts from the one with electric windows!
can't see there being an issue, if you have all the parts should fit right in, unless the door carrier is different which you can just change to the one with electric windows anyway if you have access to it
Well I've got the whole car to transfer bits I need across!
No problems........... I did a mk3 golf swap......................swap all the window carriers as different, swap door looms, and also have to put in the extra loom which goes under the dash from one side of the car to the other (power & drivers door control).also another fuse & relay I think from memory.............
