Powerflex top mounts
If you're going to change the top mount bushes, it is worth getting new bearings at the same time, it's a small cost from the dealer and they should match up the Powerflex.
Now I have read that the powerflex are pretty harsh.  Have you looked at LCR Top Mount bushes to see if they fit?
They were fine for my Mk2 Fabia, but I suspect you guys may have different top mounts and it may need to be the Ibiza Cupra ones.
David at Sere Motors sorted me mine out and helped check the part numbers to make sure I got the right ones.
Beauty is that the LCR ones are plenty harder than stock but not as extreme a shore as the Powerflex so better allround comfort retained.
I'm not fussed about the stiffness it's got a powerflex dogbone mount and it will be erring vibratechnics engine mounts soon anyways, thought I might need new bearing jus wanted to be sure ! Cheers
They won't fit mk1 Fabia it's says 2008 on
As Dav says, these are for the mk2 Fabia. I'm not sure if it's possible to get then to fit, never really looked at a mk2 setup..
I thought they shared the same suspension setup! I dunno :P
Suspension may be, but the top mounts are certainly different
