Oil warning light
Hi all when I Rev the car or drive it the oil warning light comes on I've checked the oil that's fine changed the oil pressure switch still does it I'm guessing it's oil pressure its self oil pump just wondering if you guys had any ideas ?
You need to put a pressure gauge on it as a matter of urgency.
Yeah hopefully tomorrow will get it tested
It's purely when I Rev it it doesn't come on when ticking over
Orange or red light?
Red mate
I'm guessing you've already changed the oil pickup pipe/strainer in the sump?
Red mate
Eeek. Pressure problem then. It could a blocked pick up in the sump. Unless you want a new turbo, be very careful with it.
The pick up and sealant for the sump are cheap, so worth doing regardless of anything else.
Just had a new turbo fitted that's why it was off the road went at combe the other week but will check the pick up pipe tomorrow cheers mate
So that could be why the turbo went in the first place [emoji17]
Yep, pick up blocks up and reduces the oil flow and the turbo is at the top of the system. Did you get the oil feed pipes replaced with the turbo?
Defo mate
Seems the route problem was not fixed. Who changed the turbo. As a good mechanic would also check pick up pipe and oil return pipes. The red light means low pressure. So if you are only ticking over the light may not come on. But the minute you rev it or put under load the pressure will register low if a problem. This could be oil pump but generally the pump is effected by oil circulation. So first thing is remove pick up and flush it or replace it. Then replace or flush through all oil hoses. If these are blocked they can restrict oil flow and trigger pressure problem. This in turn will cause turbo to run hotter as less oil cooling it and very quickly blown turbo. Do not drive it far or avoid driving if possible.
Cheers guys will keep you informed and bowders did you get my payment?
Yes mate
Yes mate
cool :-)
Another victim of the pickup pipe!  Is it running full synth oil?  What miles has it done?
Don't get it...had the pickup replaced as a matter of course at 80k, only 25% gunked up so how come you guys have issues? No service history?
Could be previous owners using semi synth and not changing it regularly, poor oil quality...
The pick up was blocked solid so fingers crossed will be sorted tomorrow once I get a sump gasket will let you all know [emoji4]
You will need sealent for the sump not a gasket mate.
Oh cheers bud [emoji4]
cheers [emoji1]
number of factors buddy
poor grade oil / not correct spec for car
infrequent changes / lack of services
short start /stops journeys
Right guys I'm stumped changed feed pipes changed the pickup pipe the oil pump looks new and the thing is still beeping at me I've ordered a oil pressure test kit cos I'm buggered if I'm paying £50 to a garage for them to do it when I can buy a kit for half that but any ideas would be most helpful
Dont think you can know anything for sure until you get a gauge on it
