Fabia Air Con Question
I have noticed many times that when people mention the fabia air con... they mention that it is always running and not on a separate clutch system.
Turning on the AC mearly opens a valve to let air through...
Sooooo... what i'm leading to is:
If AC is on... is there any difference in fuel consumption as to when its off as its supposed to be "always running":confused:
Sorry if this sounds stupid, just i try not to use AC thinking of fuel yet with the cooler weather im always steaming up without it.
Dont know your answer but can't say I notice any difference with mpg with it on or off. Most of the time mine is on unless I want the window open. Be intersting to see what the answer is.
I notice a decrease in fuel economy with it on and I've always wanted to know this but never bothered to ask the question... awaiting with interest.:thumbup:
Glad someone asked the question as I've always wondered but thought everyone knew and I would therefore look daft. I too wait with interest :)
Hmm, my theory is that it is always at say, 2%, even when switched off. The more you ask of it (REALLY cold etc) then the higher the load, so more fuel used. However, even on the highest demand I wouldn't expect there to be more than 1mpg difference...
Just my tuppence worth. :rolleyes:
In my 1.4/16v, I notice quite clearly going uphill in a high gear that switching on the A/C reduces pulling power, and switching it off increases it again. So the A/C does apply an extra load to the engine and therefore must decrease MPG.
Sal
When I checked with Vag-Com, the actual fuel quantity injected at idle was 0.4 mg/stroke with the aircon off, and 0.6 mg/stroke with it on. I think the extra fuel is used to maintain the idle RPM.
Exactly Sal, it is allways on, but the loading does change.
What changes the temp inside the car is a small motor on the temp flap on the heater box which alters the mixture of hot and cold into the car. The Climatic ECU monitor the in car temp through a small sensor and moves the flap backwards and forwards to try and keep it as stable as it can.
Glad it wasn't just me wondering then... always takes a stupid question to get the answer!!
Thanks for the replys, more AC just not to drastic temp changes :thumbup: bye bye steamy windows!
