vcds in birmingham?
Anyone with a vcds around Birmingham willing to help a fellow member out, I have messaged 5 people from the map over a month ago with no replies,
All I really want is the needle sweep :P and the lights to come on when I lock/unlock
My cars a Octy II 2005 :) thanks
Lights should come on when you unlock. It's a standard feature not a setting in VCDS as far as I know.
More like there is another cause of this issue.
I doubt needle sweep is available on a 2005 Octavia due to having older controllers fitted.
I'm in Worcester and free on Thursday early afternoons if that's any help, but I don't think you'll be able to resolve these with VCDS.
No they don't been told it's a coming home feature, and been told needle sweep can be done unsure tho,
Thanks for the offer but I work Mon - Friday 12-9
I see you now mean the exterior lights to come on when you lock/unlock!
Not possible on a 2005 Octavia AFAIK. Especially if you don't have auto lights.
You are right, it is LHL/CHL you are referring to.
You can get CHL of sorts to work. You leave the lights switched on and they automatically go off after a set time period (set with VCDS) up to 60 seconds.
I activate mine each Winter and turn it off each Spring.
You can get auto light retrofit kits from Maplin
Needle sweep can't be done on my 2006 Octavia, so I really wouldn't expect to work on your car.
I think I will just cry my self to sleep now
Yes that is what I'm referring to
If I was to buy and fit this stalk
Ebay num: 400757528289
I can get cruise control coded via vcds yes?
Depends what steering controller you have fitted at present.
It might support CC.
Have a look in the Ross Tech Wiki/website if you know what your steering controller p/n is.
I'm on the Acocks Green / Solihull border
Free on weekends?
And is there any fun things that can be done to my car as I was really looking forward to a needle sweep lol
Yes normally I'm free (except this weekend coming)
The only way to tell 100% what can be done is to plug it in and look at the options available to us.
Mate would you be free this weekend coming up to code my 35w hid kit as iv just blown the wiper motor and don't won't to blow another :(
