Wheel bolts for oz alloys
Beem googling it but can't find the info I need :( will my standard bolts for my new oz superturismo wheels or do I need the other sort? If so what size is needed??
Why don't you just try fitting one, it'll take you about five minutes to find out!
Standard vrs bolts are radius seat, majority of aftermarket alloys are taper seat bolts.
They are not interchangeable :)
You will need
M14 x 1.5 30mm length with a tapered seat.
I'll drop a bolt in and see and then get some ordered. Cheers guys :)
0445EE03-949C-4ADD-AB33-69F5F99F52E5_zps
Are these right or should I go for tuner bolts?? The bolt homes look normal size so it should t be a problem these are 19mm should it?
If they are like my TD's the hole will be quite tight,and you end up marking the wheel with the socket.
I've got tuner bolts :)
Will using tuner bolts on normal size holes be ok? Want to get them ordered so I can swap my tyres over later this week and for them without messing about. If I go tuner bolts I can get a nice black set....stealthy :D
Yeah fine in the hole,the tapered part is the same size,just the end is different.
Black bolts FTW ;)
Cheers Kev as always your knowledge knows no bounds :) I'll order them now
Usually the heads are for 17mm socket as well..............................as per OEM & it helps with the tight recess in the wheel
