running/ boost issues
Hi people iv just got a vrs and having a few issues with it. it had been re mapped so i put the scanner on and it come up with a few codes but only ones that come back on it the intake motor flap that has been removed and glow plugs. it starts first thing in a morning no probs.
anyway iv had it re mapped again and it was still the same
i then disconnected the maf sensor and it ran much better, i looked the part number up on google and it came back as a 1.4 polo maf so i put a golf pd 130 on and seems to have made it much better but now and then it will not boost but when it does it seems to pull strong. i have cleaned the turbo out ect and works ok.
tried another map sensor on and its still the same.
it also black smokes when its wont boost and has a diesel knock in 1st and 2nd sometimes.
im now at the stage where im not sure what to try now so could do with a diagram to check the vac pipes from the n75 the egr has been removed but do both the pipes need to be blanked off ?
this is the vac box
10407676_10203731488660927_1171295185769
mines doing this when on full boost in 5th like limp mode no turbo engine sounds deeper switch ignition off and on and its back
have you had it plugged in.
no had my vcds and plug in equipment pinched looking in to it this weekend
Have they been arrested and it found yet? :(
****ing hate thieves they want there hands cutting off.
this is what mines cumming up with it anyone can shed any light ?
mines just decided to kill the turbo
I think I know this car.
Looks like it's had some decent kit on it and lots of money spent on it. Have you double checked the vac pipes?
