Done something silly
Been playing around and updating my Columbus and thought I would try and fix a niggling fault with mt bluetooth module
Whenver I san with VCDS it comes up under 77 module not coded
Did a search and found out that although I thought I had coded it and it works perfectly perhaps I hadnt coded it correctly in the Can Gateway .So following a read though I found on another forum I made some changes I thought were logical and they didnt work
I took a pic with my phone of the setting changes I made and the original long coded but I have changed them all back and now how the following error
Can Gateway incorrectly coded Fault 01044
VCDS -- Windows Based VAG/VAS Emulator
VCDS Version: 12.12.3.0 (x64)
Data version: 20140822
VIN: TMBBF73T999033688   License Plate:
                Address 19: CAN Gateway       Labels: 1K0-907-530-V4.clb
Control Module Part Number: 1K0 907 530 S    HW: 1K0 907 951
  Component and/or Version: J533__Gateway   H16 0210
           Software Coding: E9A1FF04500602003303
            Work Shop Code: WSC 33361 790 00999
                      VCID: 37770FC856110AA66A7-8062
1 Fault Found:
01044 - Control Module Incorrectly Coded
            000 - -
             Freeze Frame:
                    Fault Status: 01100000
                    Fault Priority: 1
                    Fault Frequency: 1
                    Reset counter: 228
                    Mileage: 131885 km
                    Time Indication: 0
                    Date: 2062.14.11
                    Time: 19:15:21
I dont know where I went wrong here obviously something changed but dont know how or what
Any advice?
Its an 09 Superb Elegance
First place to look would be the installation list in 19-CAN gateway to make sure only controllers fitted are ticked and that all fitted controllers (i.e. 77-Telephone) are ticked.
Check that and we'll go from there.
Even easier option - look in your c:\Ross-Tech\VCDS\Debug\CodingLog.txt file and every change you made is documented - just reverse the changes.
Simples :)
Many Thanks , think sheer panic had taken over ! I had turned off the steering wheel
Got a low battery now and still have telephone faults (although as I said its working fine)
Address 77: Telephone (J412)       Labels: 3C8-035-730-A.clb
   Part No SW: 3C8 035 730 B    HW: 3C8 035 730 B
   Component: Telefon       015 0723
   Revision: --------    Serial number: 35909603293033
   Coding: 020100000100000000000001
   Shop #: WSC 12345 123 12345
   ASAM Dataset: EV_UHVPremi A02003
   ROD: EV_UHVPremi_SE36.rod
   VCID: 2241CE9C35937F0EAD9-8077
2 Faults Found:
9457427 - Left audio channel for speech/telephone
          B104F 13 [009] - Short to GND
          Confirmed - Tested Since Memory Clear
9458193 - Control Module for Cellular Telephone
          B1052 14 [009] - Open or Short to Ground
Have you ticked the option for three button keypad installed in 77?  I'm sure I got your second error when I did that thinking it was the steering control for the phone (its actually some kind of overhead telephone unit found in some cars).
The first is probably due to a missing wire for the left sound channel from the BT module to the radio.  Its missing from older harnesses and needs to added manually if you want bluetooth streaming in stereo with these newer modules.
Adam
Simples :)
Learnt something new today ^ but always save a full scan anyway before carrying out any changes.
Adam
Not getting this option coming up , think the module isn't coded properly
Are you able to access the long coding for module 77 ok?
Yes but no options
I'll do a screen print when I can
Double post sorry.
Thats odd mate. There should be about 10 or 11 bytes in the "coding 07" menu. The screen print should help.
