LED bulbs
Not sure where exactly to post this, so please move if in wrong place. I have some led bulbs fitted for sidelights. I have a strange fault that the o/s bulb goes off after a few seconds with ch or lh settings. But is fine if switched on manually. How can I fix this?
Sent from my Galaxy S5
Put the proper bulbs back in ?
Yer but I prefer the look of the leds next to the xenons
What do you mean by switched on Manually?
Do you have automatic on Sidelights.
(sorry not familiar with your car model.)
Do you not always switch on Sidelights manually by putting on a switch /Lights.?
Are these Bulbs being used as DRL's and coming on automatically with the ignition. and only the front,
not as Sidelights, lit front and rear and number plate at the rear.
george
Hi yer I have auto lights. If the lights come on when I unlock the car in the dark. The bulb goes out. Means I have to switch from auto lights to off then back to auto. It will then be ok
Sounds very strange.
Is this the same with both sides?
If not, swap them around and see what happens?
No only the passenger side. I have tried swooping bulbs around and makes no difference
Is it still the passenger side when youve swapped the bulbs?
Yes it is. It's as if it's not getting enough power. But fine with a standard w5w / 501 bulb
And the led will use less power.
I dont know mate. Hopefully somebody will know!
Thanks will have a look on Google too
Right from looking on Google. Before the ignition is switched on the bulb only gets a small amount of power to light up. With it being LED as it draws a small amount of power the car thinks it's duff so turns it off. The answer is too fit these http://m.ebay.co.uk/itm/281410763586?nav=SEARCH
That isn't the answer. That's the bodge.
I know the answer is to remove and fit standard bulbs as said before
Wont they just be a resistor though?
If youve already bought 'canbus error free' LEDs then they'll have a resistor built in.
I dont think thats your problem.
Yer they are canbus friendly. I dunno as that's what I found on an Audi forum
Anyone else have any ideas before I go back to standard w5w bulbs?
Which one is best next to xenons 5000k or 7000k standard w5w / 501 bulbs.
Standard xenons?
Around 4300/5000k are standard OEM.
Yer standard. Thanks 5K it is then
