Fabia vRS, is it as good as it sounds?
Springs
  • Replies 58
  • Views 5.7k
Afternoon (first post). I'm going to test drive a vRS soon at my local dealer Brookalnds Rugby. I wasn't initially sold on the type but from what I read, it sounds like a good compromise all round. Added to that an ODB remap can add all that power :devil:
Question for you then Walkie. What for
Eibach issit?
Eibach springs :)
Thought fitting springs without upgrading the shocks too was a no-no ? Doesn't it wreck the ride ?
I've been thinking bout doing just the springs but some "knowledgeable" people way up here in the Northern wastes reckon that would be bad.... :confused:
For me the job isn't worth doing without the full setup, the fronts are a real pain and if you are going to pay someone to do the job for you then it's a false economy. Not so bad if, like me, you can do it yourself - still a ballbreaker though.
That said, some people are running just springs on here and report good results but I wonder if that's compared to standard and without trying the full setup. I ran just springs on a Saxo VTS and it was incredibly harsh.
By just doing springs you will reduce the life of the standard setup.
http://www.briskoda.net/forums/showthread.php?t=28735&highlight=eibach+standard+dampers
Plenty of other people on here have just done the springs :)
This is definately the next thing im gonna do to... :-)
The magazine AutoMotor and Sport did A test with the Fabia RS.
The maximum power is 144bhp and not 130bhp in A standard Fabia.
Here is A video clip from Sweden with my friends Fabia when he got the second best time in A superstage against other Ocatvia and Fabia.
Top speed for him in the clip was 106mph.
Filename karlzzon final.
http://www.savefile.com/files.php?fid=7092542
The springs will work ok with the standard dampers, but the set does 'belong' together for a reason, and the standard dampers will be stressed a lot more as their used range is reduced by about an inch. They'll work fine, just not for as long I suppose.
As I'm gonna end up paying for the labour anyway, I'm gonna drop both on at the same time, rather than doing it in two goes.
