Best suspension
Planning on dropping the height of the octavia just a bit seen a few different brands of kits out there but what have you guys used or would say us best to use .
Many posts giving opinions on this subject - do a search.
Various options...
Springs...PI? (Cheapest)...Eibach ?
Dampers...Bilstein B8 (Possibly the best) ...Koni FSD (Popular)
Why not give Al @ Awesome GTi a ring..They did mine (Bilstein B12 Kit...B8 Dampers with Eibach Pro springs)
He can discuss all the options with you
  • Sponsor
Are you wanting springs, springs and shocks or coilovers and did you have a budget in mind?
Damian @ DPM Performance
Spring and shockers or coilovers buddy not sure what would be best .
Up to 350ish
I got pi springs 30mm (vrs) on koni str.t dampers and im happy enough. Depends what your after. I honestly dont think id be happy with anythin less then a 30mm drop. Just be warned though to look into exactly the drop your gettin. Pi 30mm springs are for a vrs and will drop it 30mm but other makes for example the 50mm h+r springs will only give you the same 30mm drop (aprox) because the 50mm stated is from a standard ride hight of a none vrs
The Vrs is already 15mm lower than standard as is the Sport which I have. I have the Bilstein B8 and Eibach Pro kit which dropped it a further 15-20mm. It sits nicely now and looks just how I would expect a sports model to look, not on stilts!
  • Sponsor
Up to 350ish
For within your budget it would be one of the entry level coilover kits from the likes of JOM, FK or Prosport.
For springs and shocks you have kits AP, Apex and Vogtland.
Do they do a spring that will actually lower your vrs 40-50mm?
Yes.
And budget doesn't really match the thread title of "Best Suspension".
  • Sponsor
To get a true 40-50mm drop on the VRS model you're going to need to go for coilovers really.
Will look into it a bit more or hold of till I get a few extra quid to spend on a kit I think
